Face Mill Next To Ledge
If you are using the Superfly tool I think you could replace the insert tool with a hand ground tool and cut too the wall with no problem.
Jimsehr
I know I could grind the tool in a short time.
Ok no wonder, you should be able to grind a HSS tool bit that would do both the shoulder and surface at the same time
