- Sep 28, 2013
- 4,325
Whittle out a piece that fits out of whatever you want, cast iron, steel, alu, plastic, wood, doesn't matter. Hold it in place and drill through it into the body of the piece. Add screws and pins to suit. You can even add as strap around the periphery and screw that into place. Then ream, file or sand the hole to the correct size. As an added touch you can then paint it and most likely no one will ever know the difference.
