- Nov 8, 2012
I'm in need of a few extended reach drill bits.
Looking around, I see various types like: Extended Reach, Chip Clearing High Speed Steel Extended Reach, & Short Flute Extended Reach.
Wondering what the advantages/disadvantages of the different types were ?
Also wondering if anyone sells them in small sets (5 or 6 sizes) vs full type sets running $1000+.
Buying singles is option, but thought small sets might come with price break over singles for same number and sizes.
Was working on a part that I couldn't drill ( on lathe) all the way thru with standard drill bit.
For prototype, I'm using aluminum and just reversed the piece and drilled from other end.
Drilled undersized and used reamer to finish and true the hole, but final piece will be stainless and not sure if this meathod would work very well.
