- Feb 19, 2016
- 326
My family has built several welding positioners over the years. Some of them had hollow spindles in them for shoving drill pipe, drill collars thru to do hard metal on them as well as stub welding tool joints and such. The spindle would run on either cam roller bearings or mounted on pillow blocks. The spindle itself would get a band of either copper or brass buildup applied and turned down to a smooth finish running true with the spindle. Next, we would bend a strip of copper bar around the spindle and held in place with insulated fasteners. Usually micarta washers and bolts to insulate the copper bar from the frame. You would attach the ground cable to this copper bar. Doing this would keep most of the current from passing thru the bearings and gearing and direct the current to the weld area. Oh, forgot to mention, a sprocket was mounted to the OD of the spindle usually on the tail end of the spindle. Used a chain drive to a gear reduction DC operated gearmotor. Ken
Thanks Ken, I think that the chain drive to a gear reduction motor is the rout I'm headed. The little motor I have only has a #25 chain sprocket....I'm looking to build a smaller positioner.......something that I can tote around and store.
