- Apr 21, 2015
- 588
Thank you, John! Fantastically helpful info there (and you guys are eventually going to shame me into painting my lathe!). Both of you will end up with machines almost too pretty to use.
I'm new to the forum and I'm still catching up on all the great content here. I've just spent some time reading posts you mentioned: MBFrontier's rehab thread, your rescue thread, and JST's posts on the practicalmachinist site (especially this one).
[Off topic, but from the photo in comment #157 on your thread it appears you have flat, scraped ways? My Wards 2130 has vee-ways as well as flat that don't appear to have ever been scraped. Did you do the scraping?]
Earlier today, I spent some time carefully measuring the radial movement when I pull on the spindle (or on a chuck with the spindle) with a reasonably measurable amount of force (I used a hook type luggage weight scale to pull on the bar). I'd post photos, but I just loaned my son my phone with the pictures on them (he's visiting from overseas).
Unsurprisingly, there was more movement with a chuck than with a morse-taper drill bit stuck directly into the spindle. With about 40 lbs of pulling on a 3/4" bar about six inches from the spindle (a pretty heavy lean backwards, imagine hefting a suitcase weighing just under most airline's weight limits) I could get up to 0.0008" of deflection at the spindle. Interestingly, I noticed that with my 6-jaw chuck I got a lot more deflection when I measured the bar deflection right at the jaws (about 0.005") than when I measured on the outside of the chuck itself (which showed the same 0.0008" deflection as at the spindle). Clearly there is some internal movement of the jaws at work — this was enlightening.
BUT I did this measuring with the mag base on the cross-slide (hey, I have all this nice flat cast iron back there now, I want to use it!). I just read that the proper way to measure this deflection is with the mag base on the headstock casting itself, because the ways themselves can actually twist/warp slightly with this kind of pulling (makes sense to me).
Also, I'm unsure, but it sounds as if the new front bearing I bought from Logan Actuator is actually a "a double row internally preloaded ball bearing." Per JST, "[internally preloaded] means it was made with zero to negative 'clearance', and there was no 'rattle space' as there often is in a standard ball bearing." Yet more reason why the Belleville washer at the front is unnecessary.
Amazing how much I'm learning on this site.
More updates soon as I continue my investigation, but I'm increasingly confident that I'll get things stiff enough to eliminate the chatter, even if I have to resort to JST's pre-load mods (which looks to be a pretty big job). From his posts, by the way, JST definitely sounds like someone I'd enjoy spending a few afternoons with — he really seems to know his stuff.
Since I only have one lathe, it's kinda like re-building a plane as you're flying along. Without another lathe to refer to, I'm unsure what's "normal" and I'm loathe to tear apart my lathe again because I can at least turn parts on it now, chatter or no!
Regards,
Rex
Regards,
Rex
