- Nov 25, 2015
- 8,318
well, the euro edge finder is much more accurate than my American straight style. The wiggler and the euro are almost a match for repeated centering tests. I re-ground the shaft to fit a 3/8 collet. ahhhh. I am within 2 to 4 tenths of a thou on the wiggler on center repeatedly. It kicks over so much better. I tested both the small and the next larger one.
Before regrind..
After a regrind:
I did manage to break an arbor on the toolpost grinder on the lathe. On the last pass, I turned the lathe on and I thought it fed into the chuck , but it was the chuck that started coming off the lathe spindle. I grind in reverse. On my old Cushman chuck I had installed a set screw that held the chuck on. The new to me Bison does not have enough room to do that. The boss is just too small. I don't know what I will do about running in reverse now. Someone on here mentioned that they glue the chuck on the threads using CA... I'm not so sure I like that idea. Maybe I'll try medium Loctite and just clean it with acetone each time rather than having to heat the plate and spindle to break free the plate.
Before regrind..
After a regrind:
