- Jun 12, 2014
- 4,816
Acra sells that lathe, it is available in a 1340C and 1440C size with a D1-4 spindle mount. I have had the ERL-1340 for around 2 years, it is a very nice lathe. If you are interested in the Acra version, I recommend contacting them directly (Tom usually does the sales) and you can usually get better pricing then through a distributor, below is links to the description/specs. Acra may have it in a 1340 version, really no difference between the 1340/1440 version other than headstock height is slightly larger. Kent also sells the same lathe but they call it the TRL-1340, they are all made by Sunmaster in Taiwan. The advantage of the QMT 1440TL is the 2.5" spindle bore and the one piece cast iron base, it is also 1000lbs heavier. I run BXA tooling on mine, because it is what I had, but both 1340/1440 really are sized for CXA. If you have some specific questions you can PM me. I modified mine so it is not stock, but they sell it in a standard 3 phase version (single speed or 2 speed motor) and a 2 speed VFD version.
1440C Precision Gap Bed Engine Lathe – ACRA Machinery
acramachinery.com
Acra 1440C 14" x 40" Precision Engine Lathe (MADE IN TAIWAN) - ATEL1440C
Unlock precision craftsmanship with the Acra 1440C 14" x 40" Precision Engine Lathe - Your key to superior machining.
www.penntoolco.com
