- Dec 20, 2021
- 868
I completely agree.Yeah, but sadly arbor presses big enough for broaching aren't ideal for budgets haha
I also agree hydraulic presses are not ideal. However, with the press linked, the cylinder is threaded into a plate bolted to the upper support. There is ZERO play. It's also very square to everything, unlike those budget tool bottle jack/bottle hack presses. There is a pressure/force gauge to monitor what's going on also. Still not as good as feeling the handle of an arbor press, but SO much better than an HF press.
And all things considered, this hydraulic press is still safer than using a sledge hammer to drive that broach!
Edit: I guess since you're making a gear hobbing machine, getting something better to drive broaches is probably pretty high up on the list . If that's a bigger arbor press, this machine would probably justify it...
Something just crossed my mind. Once you get the machine up and running I could use a couple of brass gears for my old sheldon lathe, if you're up for a small paying job...
