- Nov 23, 2014
- 2,609
Hi guys,
Thanks for all of the kind comments! I've learned a lot from reading other guys posts and think I've come up with some decent ways to make stuff. Not always the best way, so appreciate any comments on techniques that could cut out a little more time. Just documenting the processes I use which maybe will help someone else out at some point. There's always more to learn in this hobby!
Honestly, this is not a completely philanthropic endevour on my part as I sell what I make. I sold the 36 'ED' hoists from my first run for $175 at shows. On eBay they went for between $160 and $225. The 'BM' clam shell buckets go for $150 at shows, made 24 in the first batch around 8 years ago. I have an order from a collector/dealer who wants 10 of them, but I'll cut him a deal . . .
I'll continue posting some of the other parts that use techniques I've learned from others or come up with on my own. The biggest enjoyment I get out of making these parts is coming up with new and better ways to make them.
There's a picture attached of a blue wooden shift knob that was included in sets with a motor from 1938 - 1958 or '59. It's 5/16" diameter, 7/8" long and has a 5/32" hole up the middle 1/2" deep. I used to make them on my Rockwell 10 x 36 lathe with a taper attachment. Ran the 5/32" drill bit in the end of the dowel, then backed it off just a touch. Left the bit there to act as a tail stock center of sorts. Then plunged in a HSS parting tool at the top of the knob near the drilled end to break the grain of the wood. Then ran the HSS parting tool along the side with the taper attachment set at a 3 deg. angle. Little bit of triangular file work to radius the knob handle at the drilled hole and the end of the knob, then finish parting off. I could make around 40 an hour with that process. I made up around 300 of them for a show and sold them all for $2 each. At the end of the show, a guy asked if I had any more of the knobs, "nope, but I can make more, how many do you want?" 500 . . . Not a typo, 500 of those wooden knobs. No doubt he was planning on selling them at a profit, but I was happy working for $80 an hour at $2 each.
However, I was not looking forward to standing at the lathe for 13 hours making shift knobs! So, I cut the knob profile into a piece of O-1 and hardened it. The cutter acts like a scraper on a wood lathe. It worked really well and got me from around 40 per hour up to around 80. I did develop a very bad habit of stopping the lathe by dragging my hand on the spindle nose protector (was using 4-C collets on the Rockwell). I later made a brake lever that mounted to the lathe bed with a pivot on the back side. The lever was simply lifted manually until the top side (it was made from hickory) dragged on the spindle protector.
Bruce
Bruce
