- Dec 25, 2011
- 10,513
I would buy a good 3.jaw chuck first. If you later decide that you have a need for collets for small work, ER32 and ER25 are more suited to a 6" lathe. And whatever size you decide upon, make or buy a screw-on collet chuck with 1"-10 threads, not one mounted on a 2MT arbor. The 2MT arbor mounted chuck is only good for parts up to about 2" to 3" long unless you use a steady rest. Whereas the threaded type can handle any length so long as the stock will fit through the spindle.
Also, to make an ER collet chuck of either type and any size, you must be able to cut metric threads. Which probably means that you will have to acquire the gears to do whatever thread you need as they did not originally come with the machine. And if you decide that you must make a collet chuck, at least buy the compression nut. You basically can;t make one for what you can just buy one for.
