- Sep 28, 2013
- 4,318
thought this might be useful, especially with an extra special ingredient - hex stock for the chuck body! That way I can also use it to cut flats on the mill
This was partly inspired by the one on deans photographica website, which is a rich source of project info. Especially useful were the gears needed to cut a 1.5mm pitch thread. http://www.deansphotographica.com/machining/atlas/ER25/ER25.html
stock left over from cutting of the piece I needed
sawn end faced off. Lots of really light cuts with this much stick out and interrupted cuts
spindle hole drilled and bored out, with spindle register and threading relief (you can just see it at the back) cut ready for threading
threading done I'm still amazed when this works out!
