ER-40 D1-5 Mount
ddickey
H-M Supporter - Gold Member
Apr 21, 2016
3,572
I can't seem to locate any direct mount. Has anyone heard of any?
There is no direct mount D1-5 ER-40 chuck that I am aware of. The easiest way is to get the flat back ER-40 and attach it with a back plate. You can also get less run out.
The Tormach appears to be a good candidate. Any other suggestions?
Did you ever find a solution? The ER40 chucks that I've found are all setup to mount to a D1-4. The ER40 chuck on my older D1-4 lathe might have been my favorite and most used chuck.
No. I botched two back plates. I bought the Tormach. It had a 1mm. register w/100mm. diameter which fits right over the holes for the camlocks. I did get it mounted but the TIR was unacceptable. It sits on my shelf. I did buy a MT3 ER40 collet that I use with a drawbar.
In the future I plan on buying one with a larger register. I looked at the ones that Arc Eurotrade sells but they have no idea what the accuracy might be.
Well, I'm planning to buy one of the thick South Bend backplates from Grizzly (to avoid hitting the camlocks) and see if I can't machine the register more easily. I can't find any other options, unfortunately.
I was thinking about trying my hand at making my own back plate. I still have the material but I don't think I could do it accurately enough.
I'll probably go with the grizzly option also.
You can re-cut the register on the chuck, either hold the chuck in a 4J or clamp some 1" rod in the chuck and hold that with your 4J. This should center the chuck relative to the collet. Should not be any significant deflection if you are not taking deep cuts. I was also considering something similar and planned to use the extra thick SB back plate. I am considering cutting the register deeper on the ER chuck and making some form of set-tru adjustable tapping for 4 small Allen set screws. When cutting cast iron in this setting, I have found that very sharp CCGT or WNGT inserts cut very nicely, I have used these on several back plates.
somehow I never considered re-cutting the register on the chuck over cutting a new register on a back plate. <face palm>
Making a back plate is not that hard. Rough the diameter on the lathe, go to the mill and put in the holes for the lock pins and screws. Mount the plate on the lathe. Make sure and mark the spindle and plate so you put it back on the same way. Now cut the OD of the plate and registration area. No way if it's cut in the lathe spindle it won't be concentric.
