- Jan 21, 2013
- 875
I thought I'd share some thingiverse links to the upgrades that I've made for the Ender 3
Belt Tensioners:
Cable Chain for the rear wiring harnesses:
Rear Cover for the LCD Display:
Petsfang cooling duct: designed by an engineer who does this for a living!
extruder knob:
filament guide: I found that you don't need the popular guide up at the top of the printer if you use this.
If you decide to add a Raspberry Pi to run Octoprint on, then this case is just the thing:
Raspberry Pi Cover: This also has a box and lid for a buck converter if you want to power on the raspberry pi with the printer's power switch.
You can get stepper motor damping mounts to greatly reduce the noise, but the newer Ender 3's have a press-on pulley that may keep you from using them on anything but the Y-axis. You need this adapter to use it.
Y-axis damper mount:
I highly recommend this youtube channel: I've learned more from this guy than from anyone else. I just changed out the stock motherboard for a MKS Gen L board with trinamic steppers following one of his videos. It's eerie how quiet the printer is now. The stepper damper isn't even needed now.
Teaching Tech:
Belt Tensioners:
extruder knob:
Teaching Tech:
