Enco Tool post Question
twhite
H-M Supporter - Gold Member
Sep 10, 2022
949
I have this Enco 4 position Tool Post. As you can see it has 3 fixed a one for holder. I am thinking of using this on my 13” Clausing Colchester. The only problem is I only have the one holder. Searching for other holders to no avail. It looks like the 35 is an odd size.
I will verify if this will fit on my lathe once I fix the QCGB. If it does.
Does anybody have any laying about? Or know where I can get some?
I might have to make some. That would be a good project I guess.
Thanks
Cutting oil is my blood.
Given a mill, it would be relatively easy. You wouldn't have to concern yourself with fitting the fourth station, just set it up with a cut off tool or some standard chamfer, etc.
Yes I do have a mill. I have made a Norman type and a regular plunger tool posts and holders for my smaller lathes. So this would be straight forward. I then could make some custom ones also.
