- Nov 22, 2022
- 401
Yes it will move in and out, But not without holding it to the left or the right, There is a little notch behind it that locates whether it can be pulled up for longitudinal feed or pushed down for crossfeeds. If the lathe is not running you will need to grab a hold of the handwheel and traverse the carriage by hand until it pops into gear. Same with the cross-slide, Once in awhile they are lined up to engage with nothing turning, But not usually.Morning Harry,
I tried WD40 to free it up and no joy. The tag next to the lever indicates that it should move in and out. I soaked it again and hoping for better results today
In your pic the lever is centered, It will not engage with it centered.
