Enco 1525 8x36" vertical mill
Dutch
May 27, 2011
49
Bought this used 2 years ago from someone I knew in Wisconsin and had it shipped to me here in northern California. I've not been disappointed with it at all. It's a very solid mill. It was manufactured in 1993. The DRO is actually American made in Chatsworth, California (I use to work in Chatsworth).
I installed an American Rotary 3ph converter so it has the original 1.5hp 3ph motor with 10 speeds. It has lots of power.
Two months ago I installed the column riser. On sale at Grizzly for $180 I took the chance. It was a drop-in installation. Not a single problem.
I paid $1,700 for this mill 2 years ago and it has paid for itself 2x by making long eye relief scope mounts for vintage Mauser military rifles.
Gewehr 1898 German WW1 infantry rifle 8x57mm
Swedish m/1896 6.5x55mm
Dutch
Re: Enco 1525 8x36
Dutch
Dutch, do you have the part # for your riser?
Re: Enco 1525 8x36
platypus20 link=topic=2300.msg15288#msg15288 date=1306607609 said:
I have the Jet version of the same mill, a Jet JVM 836, it also the same as a Grizzly G6760 and a few others. I love mine, its been a great addition to the shop. I did power feeds on the X, Y and Z axis, other than, that the only thing I bought is tooling.
jack
Jack, how did you go about attaching the power feed for the knee? Any special issues?
Re: Enco 1525 8x36
platypus20 link=topic=2300.msg15675#msg15675 date=1306978810 said:
The knee kit was pretty straight forward, it did require a couple of new holes to be drilled and tapped, but nothing major, it took about 2 hours to install.
jack
That is nice to know. What brand/model power feed(s) did you use?
Dutch, I noticed the rifle rest that you are using for the mauser. Do you have any specs (prints) on it? I have been wanting to build one like it for myself.
