Then my next step would be a auxiliary contact blocks on the front of the CU-11 contactors. The control power should be connected through the Normally Closed (NC) contacts.
I can't read any wire numbers in your pictures, so can't help you there.
Ah ok. I can try and get some more detailed photos later/tomorrow.
I was just inspecting an RF45 manual, I don’t think the wiring is the same as my mill but I think something clicked in my head. Should I be getting 24v across the 2 low voltage terminals of the transformer(terminal 30 + 31)? I am getting a reading of 0 volts.
