- Mar 26, 2018
- 8,407
To my friends,
I've been in the Ford dealer franchise business since 1976. I've been a general manager since the early 90's.
This momentum to move to an ever increasing electric vehicle line-up, has me questioning the wisdom.
""General Motors plans to completely phase out vehicles using internal combustion engines by 2035""
High Voltage battery basics:
Electric cars use Lithium-ion battery packs -"Critical raw materials used in manufacturing Li-ion batteries (LIBs) include lithium, graphite, cobalt, and manganese."
I've seen the videos of children in the Congo working in the cobalt mines. Huge open pit mines are used for other materials.
No, electric cars, they are not zero emissions vehicles... During manufacturing, energy production and at the end of their life cycle. In the first case, the need for mining activities to extract the rare earth metals that are used in batteries is very energy consuming and polluting.
As for the energy production, if the car is being powered with energy from burning fossil fuels, it is still releasing CO2 in the atmosphere, not from the tailpipe but from some distant power plant. When it comes to batteries being recycled, it is still an expensive and ongoing process and most batteries are not being recycled yet.
The financial aspect of EV ownership.
EV's come with a 115AC charger. It will not fully charge the battery overnight assuming it was down to a low state of charge. A high capacity charger is available but must (in most cases) be installed by an electrician. We installed two at the dealership at a cost of $1,100 each (charger and labor).
Know the costs!
EV battery warranty
The EV battery warranty in this country is 8 years or 100,000 miles. I just priced a replacement battery for the Mustang Mach e. The standard 68kWh battery is $26,000.
The upgraded 88kWh battery is $36,000 to replace. That's just the battery, it does not include labor or an unknown recycling charge. Anyone know how to get rid of a used 88 kWh battery?
What's that used EV worth, knowing the looming high cost battery replacement?
Yes I'm sure battery technology will continue to improve and there are institutions like MIT that are working on battery technology that uses common materials.
Range anxiety
You planned your trip, you know there is a high capacity charging station 175 miles into your journey. Hopefully when you get there the chargers are available. Another thing about Lithium-Ion batteries, they don't like heat. Hot climates and level 3 fast charging stations can diminish battery lifespan. It has been determined that regular use of level 3 high rate chargers will cause the batteries to fail (will not hold 70% of the original capacity) prematurely.
This subject is widely discussed on the web.
I wanted to start a discussion on this subject. Electric cars are coming but who can afford them? How do we recycle or dispose of the used batteries? Know the true cost and impact before you decide to buy an EV.
Thanks,
Jeff
Know the costs!
EV battery warranty
Range anxiety
Thanks,
Jeff
