- Jul 5, 2014
- 2,776
I have a digital dash in my 55 chevy. Friday I was able to go to a cruise in and drove home in the dark. It's the first time I used the headlights.
The only real problem I had was with my high beam indicator. It's on with both the high and low beams when the engine is running. Not running the indicator light works perfectly. So it's not the led in the dash, it's something with the wiring.I contacted American autowire and they suggested putting a diode in the feed wire to the indicator. I'm not sure if that will work, but I have to start somewhere. The wiring is correctly installed.
The only thing I know about a diode is it's a one way electrical valve. I've searched and basically found that explanation and it's as far as it goes. AAW didn't specify a diode to use and I've looked up 12v diodes and found zener diodes, axial diodes, triac, tunnel, and on and on forever.
I just need a diode to prevent electrical back flow. So what diode will I need for this application?
