- Jan 6, 2017
- 1,214
I had an idea for a HSS lathe tool grinding jig.
It uses a rotatable tool holding turret, mounted on an eccentric, which itself rotates independent of the turret and base.
The middle eccentric part is machined with it's 2 faces at a 12° angle to each other, and can be rotated 360°.
The combination of eccentric positions, turret positions, and putting the blank into the slot with whichever of it's 4 faces to be ground facing the belt/wheel should allow grinding nearly any angle desired, and relief/rake angles from 0°, up to 12°.
The larger center screw secures the eccentric to the base, and the two smaller screws secure the tool holding turret to the eccentric.
I wonder if this thing would be worth the effort of making.
