- Feb 17, 2013
- 4,407
I would dearly love to find a set of 1-2-3 blocks that allows them to be bolted together. Rick Sparber's great writeup, http://rick.sparber.org/123.pdf illustrates an old SPI set that definitely has this capability. Not only are the clearance holes large enough to take the bolts that fit the threaded holes, but there are also some clearance holes for the heads of the socket-head bolts.
I guess times have changed, and at least the Chinese have decided to "cheap out" once again. Nowadays, all I can seem to find are 1-2-3 blocks that are have 5/16" thru holes and holes threaded for 3/8-16. I guess their manufacturing philosophy is "Drill 'em all the same, tap a few, and get it out the door.":nuts: Unfortunately, you can't run a 3/8" bolt through a 5/6" hole!!!
I even tried emailing Little Machine Shop. Chris replied with a suggestion to fabricate some adapter nuts, 3/8-16 outside thread and 1/4" internal thread. Yes, it'll work ... but it seems rather kludgy.
Does anybody know of a source of 1-2-3 blocks whose clearance holes will take bolts the size of their threaded holes?
Alternatively, has anybody tried boring out a (hardened!) 1-2-3 block, say with a carbide end mill?
Thanks!
Thanks!
