Use solid pipe as much as possible, the corrugated or expanding pipe reduce airflow, and that's a light duty unit.
I have a Thien cyclone that I made. Simple.
Mine is working great. I have a small DC like yours. It was given to me, it's a JET, and unfortunately it was built incorrectly. It was built so that the chips came in on top of the baffle so most wound up stick to the upper bag. I broke the welds and moved the baffle to the top, re-welded it.
I went to a plastic bag bottom, and a 1 micron bag topside.
I used 4 inch PVC pipe, and made myself a ply top. I have 2 collectors, one for 4" pipe, and one for 2" pipe. The 2" is attached to most small tools, miter, sander, drill press, bandsaw. The bandsaw also has a 4" at the bottom, 2" at the table.. Planer, Jointer, are dedicated 4"
All have gates attached.
The Thien collector works very efficiently. Cost to make back then $32 for the can, and a few bucks for the pipe, elbows. Works unbelieveable. For the 2" units it will collapse the can, so I added stiffners to the inside of the can, and created a pressure relief valve..
