- Aug 15, 2013
- 2,118
Did you try the collet for fit with the set screw removed?
Tom
True! I hadn't even thought of that. Could that be how it got sheared?
Tom
Well @higgite thanks for being kind about it! Now I need to go back in the thread and figure out which pics belong to the OP...Wobbly, I think you’re afflicted with the same malady as me. I was confusing rwm with r-mm until I finally noticed that rwm’s spindle pic didn’t match r-mm’s pics.
General question, does it seem to others that the sheared set screw in r-mm’s spindle is awfully far up in the spindle for an R8 guide pin/screw? I have a bench mill, not a knee mill, but like Jim F, the guide pin/screw isn’t nearly 3-1/2” from the end of the spindle. Mine is more like 1-5/8”. Is it common for the pin to be recessed as far in as r-mm's on, say, a Bridgeport or similar spindle?
Tom
Although the two in the picture are similar, they aren't the same at all. I can tell from the picture that the arbor taper is longer than the R8 taper. My eyes aren't good enough to estimate the taper angle. My R8 looks exactly like the one on the left, and is really close to the drawing. I'd bet the taper angles of the spindle and the R8 are different. That might account for the R8 not going in as far as it should. Only way to know is to measure it somehow.The dimensions of the drill chuck arbor in post 28 look pretty darn close to the dimensions for an R8 according to that drawing.
At 29.9mm/1.18” the nose of the spindle is not sized for an R8 collet.
It has to be a different taper.
The pin really could be just about anywhere along the slot, so that seems ok.I didn't see the similarity in the names!
The pin in my R8 spindle is 3.1" from the nose and engages the straight part of the collet.
Robert
