- Sep 29, 2017
- 2,258
Good day.
I have a SNS-3V with 5ųm glass scales on my mill and when I zero the x,y and z axis at any given point and switch everything off and not move any of the hand cranks and then switch it back on again,everything is still zeroed as I left it.
Well my problem is I have a Ditron D60 with 5ųm magnetic scales on my lathe and when I do the exact same there as mentioned above,it does not have the same effect. Zeroed before shutdown and when switched on again there is totally different readings showing. Very annoying, otherwise it is a very nice DRO.
Am I missing something? Does anyone have the same DRO with the same problem or another make with that issue? Or is it a setting I missed,although I did not had to do any settings with the SNS DRO. It was like that since the beginning. I have this Ditron for about a year and a half now and there has been no other problems otherwise.
Any help is welcome.
Thank you.
Michael
Thank you.
Michael
