- Mar 26, 2018
- 2,724
Ok, thanks guys. A lot to consider. Since I'm brand new to lathes can you help me understand which axis is which? At this point I am assuming that X axis is the carriage left and right and the Z axis is the cross slide in and out? What is the Y axis?
Exactly the other way around. X is the cross slide (positive is the direction of increasing diameter). Z is the carriage feed parallel to the spindle. A lathe typically doesn't have a Y axis. If it did, it would be vertical movement of the tool perpendicular to the floor (this is present on some CNC lathes).
On my setup, I'm just pretending that "Y" is really the Z axis.
