  • NOTICE: There are two new video channel areas set up, one for staff, and one for subscribing members. You need to create a folder. Then add your media to that folder. Once added, you can cut and paste the code at the bottom right to embed the media into a post on the forum.
    It works very similarly to YouTube, except videos are stored on our server. Click Here For The Video Channels
[4]
DRO: Mixing Mag and Glass Scales?
[3]
[10] Like what you see?
Splat
H-M Supporter-Premium Member
Mar 10, 2012
1,029
Likes
115
#1
My buddy asked me this and I've no clue. I searched but didn't find the answer. Either it's possible but not advisable or not possible which may be why I haven't found the answer. :p Can a glass scale and a magnetic scale both be used into the same display head (both being same brand)? Thanks.
darkzero
Global Moderator
Staff member
Nov 27, 2012
2,992
Likes
1,724
#2
Should be no problem as long as the scales output the same signals as the DRO is compatible with. Brand doesn't even matter, you can mix that as well.
Splat
Mar 10, 2012
1,029
Likes
115
#3
Hey Will. Yeah, I meant same signal(s) not really brand.
darkzero
Global Moderator
Staff member
Nov 27, 2012
2,992
Likes
1,724
#4
I probably should have just answered simply yes. Most of all the scales made these days all use the same signal. :)
henrivdr
Swarf
Registered Member
May 14, 2017
3
Likes
0
#5
Yes, most use a quadrature signal usually marked A and B in the wiring. However some have an extra Z index signal which is triggered at set positions along the scale, this improves the positioning at high speed. The display unit might require this.
Also check the voltage requirement (usually 5V) of the scale against the spec sheet of the display unit.
Sent from my F5321 using Tapatalk
[6]
[5] [7]
