- May 1, 2011
- 484
I will use this thread to document the entire install. I am doing 5 other major projects also so it may take a little while to complete.
This is a follow up from these threads: http://hobby-machinist.com/index.php?topic=2850.msg19687#msg19687 and http://hobby-machinist.com/index.php?topic=2019.msg13125#msg13125
As posted in the other threads, I could not mount it in a conventional manner due to the gib adjustment screws being in the way, I needed to hang it off the back somehow. So using some 3/8" x 2" flat AL bar, I made the main part of the mount, the lower leg will hold the reader head for the long slide. Then I added 1 1/4" x 1/4" angle to the underside for support and welded it with my Miller MIG and spoolgun. The welds are very ugly-I have little practice with welding AL so I dressed them up a little with JB weld so it will look nice when it all painted. I do have plenty of penetration though as evident by the end I cut off.
I then drilled and tapped the 1/4-20 holes to hold the mount, it is VERY sturdy. Next I made the 1/4" x 3/4" bar to move the reader-head, Again I drilled and tapped 1/4-20 holes to mount it.
Here are the pictures of the progress so far:
