This is a simple tool I have seen before and it may even be on this site, but a friend sent it to me on the internet and inspired me to finally build one as I have wanted to for a while.
It is simple to build
Tow pieces that I cut entirely on the band saw and welded together. I did mill a groove on the bearing block .100" deep to align the shank while welding. A hole was drilled and bored for a .500" ID bearing that pressed into the block.
A .500" OD shaft , 6" long with a 3/8 drill chuck on the end fits in the bearing. You attach your cordless drill and then you can drill a cross hole on center or turn the fixture to face drill your work. You can drill feeding with the crass slide or saddle , or you can drill sliding the shaft in the bearing block.
Simple but useful tool for the lathe
Mark Frazier
Mark Frazier
