Downloads
dlane
Sep 27, 2014
3,123
I didn't see anyway to search for somthing in downloads and looking thru 39 pages of mixed up stuff is a problem trying to find a particular download.
Is there a easy way to find what your looking for in there ?.
Under the Search if you select "More" you can choose what "Tab" (directory) you wish to search. One of which is "Downloads". Hope this helps.
Hey Derrick,
I understand the frustration.
I have poked around a bunch there and here's what I found works well if you know the specific manufacturer:
From the main page (http://www.hobby-machinist.com/) hit "Downloads":
That brings up a list of topics, click as below for an alphabetic sorted list:
Then you see a menu item for documents sorted by manufacturer:
Within that list find the manufacturer you want, I use "Southbend" in this example:
Then your down to about 500 documents, or 10 pages......then click on the search bar:
add some text to search on, like this:
(note here I checked the box to search _ONLY_ this category)
You should then see a list of items matching your search.
Yes it is a few clicks, but since I found it it has worked well for me.
-brino
