- Feb 1, 2015
- 9,645
That said, if the need is great enough to overcome the challenges, a shop made tap and die are possible. It would involr machining and hardening and tempering to produce a cutting tool. It the material to be threaded is softer as in brass or aluminum, you could get by without the hardening and tempering for limited use.
