- Jan 31, 2016
- 11,461
I thought these came in 4 sizes ? Small , medium , large and liars !looks like my last extra large condom I got :ROFL
just remember the mill is top heavy, so secure it with straps to the forklift back grate. you don't want to be one of the many asking how to fix it after it falls over. secure it good .. better safe than sorry.I went to the local salvage yard and found two steel box beams 10x12 inch with 7/16ths wall. They are both 61 inches long.
590 total pounds. So will lay the 12inch side on the floor, tack weld the two together, drill the boxes to take the bolt down for the grizz
The box beams will run in the same direction as the table giving 30 inches either side of center to stop any tipping issues. This raises the table 10 inches and will make working on the grizz more enjoyable for my back. I have a small fork lift that will allow me to lift the entire unit by sliding the forks in the box beam
Yes thanks for that! Once I won the auction I downloaded a manual and immediately learned that in the case of the 0761 and 0755 you slip a strap under the head next to the head support and lift the head, to lift the unit. Just not sure what the extra 500 pounds of weight will do to that concept. So will lift from the box beams. I have chainsawed some 6x6 into a nice fit in the box beam with the fork lift fork inserted. So each fork has a 6 by 6 strapped to the bottom of the fork, and a 2x6 on the top of the fork, I then banded the entire thing together. So when I push the fork lift into the 12x10 box beam the fork fits snug and the Grizz cannot tip when I lift it.just remember the mill is top heavy, so secure it with straps to the forklift back grate. you don't want to be one of the many asking how to fix it after it falls over. secure it good .. better safe than sorry.
We will jam the raw ends of the wire into the electrical panel with a 10 foot pole
Would love that, we are just a group of old guys who try to make stuff. Some of it works, some of it not so much. I drew the short straw so now I am the "machinist/machine operator" for the group. I soon will be the President of the "Broken End Mills Club", I will let you know when the next meeting is@Turbine-Wine What a monster of a base! wow! The mill looks in great shape - you got a good deal. Nice clean shop, too!
I'm north of you in the big C. One day I'll run down the highway and say hello...
Several of the guys here have CNCs some Haus, some homebrew. We should keep in touch.
