- Jun 8, 2016
- 603
Semi long story and background, skip down for my questions:
Couple years ago I needed to build a steady rest for my 12" Logan lathe. I got a piece of 1" aluminum plate, cut a 3" diameter hole, cut slots for brass 'fingers' and away we went. I used the on several projects with no problems. And the I needed to support a 4" diameter piece. I made the larger hole and that's where things got off track. The original hole I realized after enlarging it, was not on the centerline of the bore. At that point I realized I didn't have enough material left in the plate to get it on center and make it work.
So here I am making another steady. This time I'm starting with a piece of thick wall pipe. I'll make a base separate and weld it together so that it is on center.
But right now a question on which way to attach 'fingers' if you will. Here is the top piece I have plenty of meat for this. My first thought was to drill and tap for screws (I'll brass tip them).
And then it occurred to me I still have the brass 'fingers' from the first rest. I could slot the pipe and use them.
So I'm asking for opinions and thoughts on which way to make it.
