DIY 3-point bore gauge?
Nitrous
Apr 23, 2014
36
Hi folks,
has anyone built a 3 point bore gauge? I imagine something along the lines of a set of three round contact points, distributed equidistant with a micrometer head oriented perpendicular to the contact points. I could see a precision steel bearing ball being pressed out by an advancing micrometer spindle. The travel would be limited but I think it could be done accurately. It could also be done over a range of diameters.(using different heads into which the micrometer is fitted)
My particular application is to accurately measure shallow (ie ~.1" or less) internal bored round stock. I need high accuracy since I need to machine a companion disc to press fit into the bore hole.
Anyone know if this project has been tackled?
Doug
I have seen a DIY using 4 balls in a pyramid arrangement, where 3 balls measure the bore and one sits on top of the other three. A dial guage reads the position of the top ball and some fancy math ensues.
Of course I can't for the life of me remember what site I saw this on...
bob
bob
I suspect that a geometric relationship can be made such that there would be a direct relationship between a micrometer head's downward spindle motion and three outwardly displaced contact points. if the rise/run of the displacing spindle are equal, I suspect that for every downward movement of "x", the three contact points would move out "x'".
Doug
Cool little article. I'm going to have to make one of those. :biggrin:
Thanks for finding/sharing it.
-Ron
