- Jun 29, 2014
- 4,060
Arrggh. I read through the PM post on "How to Test Magnetic Chuck" and they indicate zero or near zero ohms means its probably toast. Mine is reading zero.I think this is good. A short to the case would be bad.
As for the resistance of the chuck, I don't know what it should be. However this link, https://www.magnalock.com/post/electromagnetic-chuck-tips-troubleshooting-your-chuck leads me to believe it should have some resistance. Do you have any information on what the chuck specifications are? This link https://www.practicalmachinist.com/vb/general/how-test-magnetic-chuck-176302/ seems to indicate a typical resistance of about 400-500 ohms. So an open circuit is probably a bad thing - as in, you will have to repair the chuck somehow.
The bridge rectifier. The mounting hole, I see has a metal ring? Is this ring isolated from the rest of the 4 terminals? I would think it should be. Is it? Make sure you Discharge the cap! Disconnect the wires from the bridge and measure it. Check each diode (one polarity across the diode should have low resistance, the other polarity of your test leads should have a much much higher resistance) and if the diodes are isolated from the chassis.
What was the DC voltage across the capacitor? What is your input AC voltage?
Another problem I discovered is that the connectors on either end of the cable are reversed. They are "Jones" style connectors, if my memory serves me well. There are two spades per end. One spade larger than the other. When I checked for continuity on the cable, the large-to-large read zero. Large-to-small checked out with continuity. I'm wondering if the previous owner replaced the cable and polarity was inadvertantly reversed and that is what cooked the whole system to begin with???
This project may be dead in the water. I do have a mechanical magnetic chuck and can still use the machine, but it sure would have been nice to get the original electro-magnetic chuck working properly.
If I can disassemble it and see what might be wrong, I'll post pictures.
Bryan
