iv got an xr100 which is not the most adjustable bike on the planet. it has no preload adjustment and from the factory, it is set up for a rider that weighs around 100lb. of course the suspension droops too much when a bigger rider gets on. some people get a stiffer spring, but then the shock does not have enough dampening action. i decided to keep the stock spring and shock but preload it so it rides higher, and still has enough dampening.
here is the part i made to do it. it is split so that i can install it without fully compressing the spring and removing the shock. i just compress the spring about 3/8 of an inch and bolt this on. this bike now feels much better.
the top isn't too pretty, since it is the raw finish of the piece i used. doesn't matter tho since it is going to be hidden by the spring.
looks alot better installed.
i actually did all the turning on my mini mill. first i turned a disk, and sliced it in half. i milled the edges so they meet up. i then milled and drilled holes for the bolts. then i drilled and tapped the two holes in the plates so i could mount it to turn the inner hole. i rough cut the center with a hack saw and freehand milled a rough circle. then i bolted it together and mounted it in my drill chuck on a fixture and turned the inside to have a sliding fit on the shock body.
