- Apr 30, 2015
- Location
- District 9
Well Erich you are now the official HM beta tester for that product, keep us posted
I have no interest in swapping (so I of a VFD for everything), but my surface grinder has an awesome motor arrangement with a really cool prewired box. Reddinr above is making me a great deal on a slightly used RPC that is admittedly oversized for my use case (10hp motor), but should get my micromaster running perfectlyIf you want to swap the power converter between machines, or if you're like me and don't want to gut out a beautifully wired machine with accessory motors to do a conversion, then a RPC is for you. I got my 5hp RPC from American Rotary, IIRC it was about $700 delivered. I think if you already have an appropriate motor you're halfway there to putting one together yourself.
I figured it was a 10hp motor, 5hp rated. Either way, it is likely significantly oversized for my setup. I've got 2 hp between the spindle and pump, plus another 1/2 for the coolant pump (only 1 phase).Erich - Just to be clear, it is RATED 5HP I think. The 10HP motor may be over-sized for that rating though. I think the manufacturer used what they had on hand for motors and added the capacitors/relays for the rated HP. I bought it from a small outfit a while back. Maybe more capacitors can upsize its rating but I don't know for sure.
