- Jan 2, 2019
- 6,554
Here's a picture of what I'm talking about.
Allthread goes through spindle, to the end of a pipe big enough for the spindle to go inside of. Thick washer or something substantial that's big enough to rest on the edge of the spindle but will still fit through pulleys, gears, etc. (it looks like in the picture above they have a big piece of bar stock, that may just be to get things started and would change to a washer once the spindle is moving, or maybe they're reinstalling the spindle here).
You will need to make sure everything that's retaining the spindle is loose or removed of course.
This is assuming the spindle is a press fit in the bearings and any other items like the pulley are snug but retained with setscrews or the like.
When I did this on my Craftsman I actually used a piece of hardwood that I bored to the right dimension.
Hope this helps, go slow and pay attention. It will require force but should not be excessive, 1/4' allthread will probably work for you.
Good luck,
John
Good luck,
John
