    Dismiss Notice
delrin vs aluminum
Discussion in 'CONVERTING A MACHINE TO CNC' started by carlsoar, May 18, 2017.
  1. carlsoar
    carlsoar United States Swarf Registered Member
    0
    1
    City:
    Rochester
    State:
    Minnesota
    -Return to Top-
    Hi All,
    is there any real reason to make a stepper motor mount for a CNC conversion out of aluminum vs delrin?
    I broke a tap in my aluminum Y axis motor mount, although the mount is fine to use still (hole for an endstop), I would like the placement there, and I have a block of delrin that could be milled to fit.
    Thanks
  2. woodchucker
    woodchucker United States Active Member Active Member
    546
    93
    City:
    Pittstown
    State:
    New Jersey
    -Return to Top-
    So delrin is more flexible, soooo, will your mount flex at all. If not your probably good.
    I would rather do it in al. So why did the tap break? did you use the correct drill bit? Did you use enough cutting fluid (tapmagic for al is what I use) ?
  3. carlsoar
    0
    1
    City:
    Rochester
    State:
    Minnesota
    -Return to Top-
    Thanks for the reply- the other reason for waiting to do delrin was finding a place to anodize the aluminum once cut. The one I would be replacing was. It's the y axis block from CNC fusion for an LMS 3900.
    I think I broke it from a combination of not enough cutting fluid and not backing out enough to break up chips. Haven't done much tapping before, and mistakenly thought I could push through a bit of resistance buildup. Lesson learned on that one.
  4. chips&more
    chips&more United States Active User Active Member
    1,260
    113
    City:
    Danville
    State:
    California
    -Return to Top-
    Welcome and sorry, but not enough info and pics, this will only get you random answers.
  5. woodchucker
    546
    93
    City:
    Pittstown
    State:
    New Jersey
    -Return to Top-
  6. Tony Wells
    Tony Wells United States Former Vice President Staff Member Administrator
    19,407
    113
    Tyler, Texas
    City:
    Tyler
    State:
    Texas
    -Return to Top-
    Delrin is not a substitute for aluminum in any structural part IMO. I would never use it for mounting a motor.
  7. ch2co
    ch2co United States Grumpy Old Man H-M Supporter-Premium
    435
    63
    Mile High Colorado
    City:
    Center of Colorado 5420ft
    State:
    Colorado
    -Return to Top-
    Aluminum! Take it easy on the taps and use quality taps not really really expensive ones but not bargain basement ones.
    What size tap were you using? I've done very little machining up until a couple years ago, but have been drilling and tapping holes
    since I was a kid. Used to break them fairly often. Time will teach you the correct way to almost effortless tapping. I have probably
    tapped 3-400 holes in the last year, mostly in aluminum in sizes from 2 - 56 to 1/2 - 18 and not broken one. Practice (and patience)
    will guide you. There are some YouTube tutorials on tapping that are worthwhile watching. Good luck.
    Welcome to the group! You have found a treasure chest of machining (and a few other things) knowledge.
    Oh, and we like pictures of what members are doing. Lots of pictures.
    CHuck the grumpy old guy
    jbolt likes this.
  8. benmychree
    benmychree United States John York H-M Supporter-Premium
    485
    83
    City:
    Saint Helena
    State:
    California
    -Return to Top-
    If the tap did not shatter in the hole, chances are that it could be removed with a Walton tap extractor; its fingers enter the flutes in the tap and a tap wrench is used to back it out; some back and forth movement of the tap may be necessary to dislodge chips and burrs, but they usually do the job. If it is a through hole, the tap can be forced out its entering end with a punch and hammer and the hole can be repaired with a STI thread insert (HeliCoil)
    FOMOGO likes this.
  9. tq60
    tq60 United States Active Member Active Member
    227
    43
    City:
    madera
    State:
    California
    -Return to Top-
    What size tap?
    If you have not much experience tapping then the cheapest harbor freight set may be good investment. ..
    We had one that the taps were not near as hard as others. .Our craftsman set is similar in that the tool steel not being as hard does not cut as well but they are not near as brittle.
    Better for hand tapping or chasing threads as less likely to snap.
    After you get proper feel for it then use the good stuff.
    FOMOGO likes this.
  10. JPigg55
    JPigg55 United States Active User H-M Supporter-Premium
    132
    63
    City:
    Smithfield
    State:
    Illinois
    -Return to Top-
    I've never tried this, but when I had a similar situation, a friend of mine told me to chill to tap with liquid nitrogen or canned air. Then use a punch to smack it, it should shatter and the pieces can be removed. In my situation, I didn't have either on hand and it was easier to make a new piece.
    microshop dinker likes this.
  11. rwm
    rwm Active User H-M Supporter-Premium
    1,090
    113
    City:
    Charlotte
    State:
    North Carolina
    -Return to Top-
    Nitric acid. Dissolves the tap but not aluminum. Order on ebay.
    Robert
  12. Wreck™Wreck
    Wreck™Wreck United States Active User H-M Supporter-Premium
    1,357
    113
    City:
    Riverton
    State:
    New Jersey
    -Return to Top-
    Why anodize a hobby machine part?
  13. Metal
    Metal United States Active Member Active Member
    95
    28
    City:
    Buffalo
    State:
    New York
    -Return to Top-
    Because over time it will react with any steel part it is touching and "rust" to it
  14. rwm
    1,090
    113
    City:
    Charlotte
    State:
    North Carolina
    -Return to Top-
    Especially if it gets wet. I just tried to get an aluminum and stainless roof rack apart after years of use. I had to cut it apart. Perhaps consider anti seize compound?
    Robert
  15. Metal
    95
    28
    City:
    Buffalo
    State:
    New York
    -Return to Top-
    Apparently, machinist people that make their own sub plates use plain old KY jelly, and they have to take it apart and clean/reapply every few years but it keeps the two metals from reacting.
  16. ch2co
    435
    63
    Mile High Colorado
    City:
    State:
    Colorado
    -Return to Top-
    Some of us just live in dry places ;)
  17. Metal
    95
    28
    City:
    Buffalo
    State:
    New York
    -Return to Top-
  18. rwm
    1,090
    113
    City:
    Charlotte
    State:
    North Carolina
    -Return to Top-
  19. Metal
    95
    28
    City:
    Buffalo
    State:
    New York
    -Return to Top-
    [QUOTE="rwm,
    "Regardless, environmental conditions remain large determinants of corrosion rates."
    [/QUOTE]
    Not that it doesn't happen if it is dry, it just happens slower
  20. Reddinr
    Reddinr United States H-M Supporter - Premium Content H-M Supporter-Premium
    18
    8
    City:
    Buckley
    State:
    Washington
    -Return to Top-
    Delrin seems soft for a motor mount but it depends on your specific set-up. I've painted aluminum with pretty good luck with no corrosion with steel in a wet climate even. For next time tapping in aluminum, maybe try roll-form taps. I've had really good luck with them for smaller holes. They mash the aluminum into threads instead of cutting the metal. I'm sure someone on this site told me about them a while back. I use some aluminum tapping oil (green can) I got at a building supply store years ago that works well. Once I started with roll-forming taps on Al, I've only broken one 4-40 tap in hundreds of 4-40 - 1/4-20 tapped holes. I broke "many" of the regular cutting taps in Al. Be advised though that drill hole sizes need to be a bit different for those taps.
  21. sabb0
    sabb0 Australia Iron Registered Member
    2
    3
    City:
    Adelaide
    State:
    Outside US / Canada
    -Return to Top-
    Yes when i used to build ally ships we used to smear durolac between the aluminum hull and any stainless fittings coming into contact.
    Sent from my SM-G920I using Tapatalk
Share This Page
