- Dec 18, 2022
- 2,564
Hey Ted, Carb Cleaner or the green can of break cleaner as long as you are careful with them. I use Awesome in a spray bottle for decreasing around the machine. You might consider buying a cheep harbor freight compressor for blowing stuff out, one of the little pancake compressors work well for that and are less than 100 bucks. Your in my old stomping grounds, hope you didn't have too much damage.What does everyone recommend to degrease a part and clean the chips out of holes or whatever. I will eventually have air in the shop again after Beryl came through and rearranged things. I do only manual machining so sometimes the part can be quite messy when I take it out of the milling vise.
Thanks in advance
Ted
