- Oct 31, 2016
- 2,645
When I was living on my sailboat I went solar to keep my batteries charged instead of running the diesel engine on the boat. This was a total off the grid situation. My experience may not be a good comparison to a house. I was in Mexico most of the time and then in San Diego. I did not find that slight shading like the shade from the back stay going across a panel made much if any difference in the amount of power that the panels generated. The biggest problem for an off the grid set up is battery storage. You can never have too much battery storage. The batteries require constant maintenance. Primarily keeping the terminals clean with good connections and keeping the batteries topped off with distilled water. The old standard lead acid batteries are the best bang for the buck.
To get a good estimate on power usage you need to keep track of how much power you use on a daily basis. This is important in determining the size of the battery bank. Then you need to estimate how many days in a row that you won't have sunshine. Multiply the number of days times your daily power usage. Multiply this by 4. Why do you need 4 times your estimated power need. The batteries in an off the grid system will never be at full charge. 80% charge is typically. You also never want to drain your batteries below 50%. Doing so will damage the batteries. A battery bank will not except a charging rate of more than around 25% of the size of the battery bank in amps. Even this will be hard to achieve. For example I had 400 amp hours of battery capacity on my sailboat. I never achieved a charging rate of more than 25 amps per hour and that was with my diesel engine using a 105 amp alternator. The solar panels never produced more than around 15 amps per hour going into the batteries. No matter how may amps you system may be capable of producing the charge controllers will not allow more than the battery bank can accept to be transmitted to the batteries.
This is just the start of what is involved with living with an off the grid system. You will have to change your life style if you go off the grid.
Based upon my experience I would never have an off the grid system in a home. A grid tied system with at most a generator backup IMHO is the way to go.
If at all possible I would not mount the solar panels on the roof. The supports for the panels require lots of holes through the roof. Everyone a potential leak point. Also if your roof and the solar panels are not in sync life span wise, you will have to remove and reinstall the panels to replace the roof. Another cost to factor into the calculations.
I was a real estate appraiser for most of my working career. Although it has been many years since I did that, I was never able to actually measure an increase in value from solar panels. I still follow value trends watching sales in my area and still can't attach a value to solar panels on a home. I think the reason for this is the life span of solar panels. The closer you get to the end of the life span solar panels may even turn into a negative due to the cost to remove and replace the panels.
As has been mentioned above what your utility company is mandated by law in your area to compensate for the power you generate will have have a big impact on the cost effectiveness of a solar system. California requires the utility to give you dollar for dollar credit up to the amount of electricity that you use and pay you at a reduced rate for any excess that you pass onto the grid. Not many states are this pro solar.
