- Mar 18, 2022
- Location
- Kansas
I finally got the 1660 off it's pallet. Most of the holdup was waiting on the gantry and a shackle believe it or not. I think it wound up taking me about 3 hours to get it to balance. I had already run the tailstock and saddle to the extremes of travel. It still wasn't even close to balanced. It wanted to be headstock heavy by quite a bit, and very rear heavy. I pretty much grabbed every handy piece of cast in the shop (the things in the pan are old stockyard scale weights if you wondered), and that balanced her out almost perfectly. I'll stick some pictures in here just in case anyone else needs to ballpark one.
I'll just use the 20 ton toe jack to set it down the rest of the way. Then I can commence to pull my hair out leveling it.
