The thing is that it will start if I spin it, and it does have a cap but I was thinking it was a start cap.I don't know. That said, I have never seen a bench grinder that size that does have a centrifugal start switch. Not really needed because of the low starting torque. Many grinders do have capacitors, but they are run capacitors, no cent. switch...
A capacitor run motor with a bad cap will usually get going if you spin it. It won't have full torque. What does the capacitor look like?The thing is that it will start if I spin it, and it does have a cap but I was thinking it was a start cap.
Tom
The parts lists that kd4gij put up shows a capacitor as well as a centrifugal switch. I am guessing your grinder has a start winding operated by the centrifugal switch and that there is an issue with the switch, the winding, or a connection. I still think the capacitor is a run capacitor.This might help, it is what came up on grangers web site for your model #
http://www.grainger.com/ec/pdf/Dayton-Bench-Grinder-2LKR8-2LKR9-2LKT2-Replacement-Parts-List.pdf
