Darex e90 stylus help
usajsb2
Nov 1, 2012
13
Purchased a Darex e90 from ebay seems to be missing the original bracket for the stylus. I"m hoping someone here has one that they could give me a few measurements its the bracket that holds the stylus looks like two angle parts. One part mounts to the base of the machine and has a pivot pin then there is a slotted part with an arc and finally an angle with a pivot and also hold the stylus. part 6,8, and 10 on the darex parts diagram in the manual. Any help would be great
Hello @usajsb2,
I too picked up a Darex E-90 that was short a few parts.
The company was good at getting me some missing ones, NOT cheap, but responsive!
Wait, by description I think you mean parts 6, 9 and 10, right?
I believe #8 is just a washer/spacer that sits between bracket #10 and bolt #3, see diagram below....
I have the following parts, new in the bags:
#9 Stylus Angle Adjusting Plate
#10 Stylus Mounting Plate
It may be the weekend before I get to measuring them....but do NOT let me forget!
If I do not post back by Monday, please PM me a reminder.
I do NOT have part #6, I was hoping to fashion out out of some angle iron, but have not got that far yet.
So if someone could supply those dimensions, I could use them too!
-brino
Yes 6,9, and 10 my eyes are bad that would be great. I did email darex but waiting on a reply. Yes if you have 9 and 10 then figuring out 6 shouldnt be too hard maybe someone else will chime in with some measurments for 6 yet. I'll wait to hear back from you when you get time thanks.
Where do you guys get decent priced diamond wheels for that Darex?
Not the best price but i just ordered one from mcmaster carr for $180 there are cheaper ones $50-100 but the diamond is only half the thickness but there are none to be had all back ordered. Mcmaster carr ships next day they had 3 or 4 different grits 4571a154 is 220 grit i have done a dozen or end mills seems good to me.
Mine came with one, and since I haven't got it all set-up yet, it seems to be lasting very well. :grin:
-brino
@usajsb2,
I haven't forgotten about this, but it is taking longer than I wanted.
Let me give some easy stuff first....see the pictures below.
Both parts are 3/16" thick steel.
I have one drawing done (in Fusion360), I just need to figure out how to generate a PDF drawing again.
I will still finish the drawings.....
-brino
Okay, I figured out the drawing creation and pdf export.
Here's the first part.
-brino
  • Stylus Mounting Plate - PP08105SF Drawing v3.pdf
Sorry for the delay.
The second part (the Stylus Angle Adjusting Plate) has some curves, that I have no idea how to capture in CAD.
So, in order to get this complete (and after days of fighting with my scanner software :mad: ) here is at least a path forward.....
I have attached a scan of this part.
You just need to print it such that the scale is correct (ie. that 1 inch on the scanned ruler = 1 inch on the print-out).
Then you can use the pattern to produce a 1:1 replica.
The original is 3/16" thick steel.
Any questions, just ask.
-brino
-brino
THANK YOU!!!!
I’ve had the machine sitting idle because the stylus assembly was missing. Picked it up from an old toolmakers estate. Super excited to get this thing up and running…JON
