- Jan 6, 2017
- 1,214
On D1 spindles, the chucks do indeed seat against both the taper, and the flat face of the spindle. As @mikey said, it's a secondary consideration. It doesn't need a ton of force holding the faces together, just contact. The taper/register controls radial runout. The face contact just prevents axial deflection under cutting forces.Have not messed with dx tapers so just guessing, assuming they do not fully seat on anything flat as the taper is the interface.
Sent from my SAMSUNG-SM-G930A using Tapatalk
The tapered nose itself is too short to provide significant resistance axial deflection due to either cutting forces, or one cam being tightened to a higher torque value than another.
There is less than a half inch of taper, so under significant cutting forces, a gap at the rear of the chuck would cause tension/compression forces be transferred into the cam pins. The amount of deflection would be inconsistent, with 3 spots 120° apart per revolution having more deflection (the gap between the pins. The pins are (3, on a d1-4) 120° apart. This would likely contribute to surface finish issues and possibly chatter.
The typical procedure for fitting a chuck that doesn't fully seat against the spindle face, is to mount up a good chuck/collet, then mount a bar into the properly seated collet/chuck. Then flip the offending chuck backwards, tightened onto the bar, and polish the inside of the female taper with emery cloth untill it seats with contact on both the taper and face. A little dyechem helps. It also helps to remove the camlock pins from the chuck, for safety.
Most of the backplates I've purchased for custom fixtures have needed this done. Some more than others. It usually takes be about 20 minutes to get a new d1-4 backplate properly fitted to my spindle.
I used a Shars backplate for the receiver truing chuck I recently made. It had a couple thousandths gap when new. A few minutes with some 220 grit sandpaper got it sorted out.
This spider chuck used a chinese backplate as well. It had a gap, and took about a half hour to get properly fitted.
It would seem that most of the new backplates have the taper made a little undersized, to allow for final fitting.
Several of my chucks were fitted to other camlock lathe's I've owned in the past, and still fit my current lathe quite well with no additional fitting required. That implies that the spindles were all the same, and the backplates tapers were undersized. I've never found a new backplate with an oversized taper. Always undersized.
Only 2 chucks I've purchased ever fit perfectly out of the box. One was a Kalamazoo 3 jaw, the other was a Chinese 6 jaw.
From Rohm's instruction manual:
Mount the chuck and without tightening the cams there should be a gap of .0008 - .002 inch. The manual states to evenly tighten the cams. The manual then states "Both the short taper and the face of the chuck must be in full contact with the spindle nose after mounting
So, with the chuck in place on the spindle taper, a gap of up to .002" should allow the cam pins to pull the chuck onto the taper, sufficiently to close the gap and bring the chuck and spindle faces in contact, providing a firm axial register.
