That's dirt cheap for a back plate, let alone one from Toolmex. If it works, I would have 3-4 as back ups so I can add whatever chuck I wanted. Direct mount chucks are going to be expensive so a back plate is a good option.
Trying to understand the features of the spindle nose set-up.
What is the OD of the flange on the flange nuts (chuck mounting studs).
Will the nuts pass through the large end of the key-hole slots (radial) in the disc (with the knurled OD).
