- Apr 23, 2018
- 6,567
Releasing the hammer spring is a good precaution. I don't own any CZs, but this type of jam I've been able to clear by knocking out the takedown (slide release) pin into a lead shot bench bag and taking the slide forward. If that's too tight, you could try holding the pistol in a good isosceles grip, placing the face of the slide against a table or block in a way that allows the barrel to clear, and leaning your weight into it to push the slide back.
That's the nature of autos. You fire thousands of reloads through them at the range, and every once in a while there's an issue. I think you could clear it yourself, but only if you feel comfortable doing it. Be safe.
