- Mar 26, 2018
- 8,412
I’ll work on this today.Ok, so here's the trick.
FIRST, pick a 'width' for your dovetail, inner-point to inner-point on the 'female' part of the dovetail. Center your spindle, and "know" the width of your cutter.
Say, you chose a 1.250 'width' for the inner points on the female part, and a .750 'cutter' width. Cut down the center (or, more likely, have cleared it out with your roughing mill) and set your depth (lets say, .200" for this), and cut until the 'points' hit their size, just like if you were trying to cut with a normal straight cutter. In this case, 1.250" wide, -.750" cutter, is .500. .500" / 2 (for each side!) is .250", so you cut until your DRO reads .250" and -.250".
NOW to do the 'male' part, you do the reverse when you 'cut', you cut the 'width' of the 'inner points' PLUS 1/2 your cutter width. Calculating the inner point is as easy as just doing the trig.
The inner 'corner' is 60 degrees thanks to your dovetail cutter. You want to find the 'adjacent', so open your favorite right-triangle calc (like this one!) https://www.calculator.net/right-triangle-calculator.html
"Alpha" is 60 degrees. 'a' is .200" (the depth we decided above). We're looking for 'b' here, which ends up being 0.11547. Which means the 'narrow' points on the female dovetail are 1.250" - (.11547 *2), or 1.01906. (1.250" because that was the 'inner width' we chose above, *2 because there are two triangles created by the dovetail cutter, 1 on each side).
SO now you want to cut the 'male' side. Target 'inner point to inner point' is 1.01906" (plus perhaps a touch for a running fit!). Cutter is still .750. Set the cut 'depth' on your part right to the .200" we decided on above. Then, with the DRO centered, cut the 'outside' of the part until the DRO reads DOWN to (1.01906 + .750)/2 (cutter size!), or 0.88453.
At this point, your dovetails should be just about right-on, as long as your DRO was. No measuring over pins, just good-new DRO + a small amount of trig
Thanks for your time with this!
