- Feb 8, 2014
- 11,145
This is a bit of a mental excersize in machining operations problem solving.
I'm working on a drill fixture for a customer. I need to install four 31/64 drill bushings, one in each corner of the fixture. The body OD of the bushings is 0.751
The Problem: The fixture material is 1/4 inch thick and the flange to end length of the drill bushings is about 1/2 inch, so they will protrude through the fixture by about 1/4 inch. This is not acceptable, they need to be flush. The bushing material is heat treated and file hard, probably around a RC62 or so. Thus carbide won't cut it.
The Question: How would you cut these bushings down to size? Assume you have access to most common equipment one might find in a well equipped tool & die and fab shop.
