- Dec 25, 2011
- 10,531
Micri,
The cross feed screw on the Atlas with power cross feed must come out of the front of the apron because of the spur gear on the screw (the gear is what drives the power cross feed). So you must remove the bearing for which you need a pin spanner. Do not stick a solid rod into one of the two pin holes in the bearing and try to break the bearing loose. You will wallow out the pin hole and probably bend the pin. There are several sellers offering various sizes of pin spanners, mostly adjustable, on eBay. The adjustable one that you need is the O-471A, which covers diameters between 3/4" and 2". Prices seem to range between $25 and $40. Unfortunately, none of the ads that I looked at gave the pin diameter, which is critical. So you will need to contact the sellers and ask what the pin diameter is on the ones he is selling. Somewhere, I have a Williams catalog that shows what all of the choices are, but at the moment I can;t find it. Don't accidentally buy the hook spanner version. The part number happens to be on the handle, which is used on both the hook and all of the pin types.
0.020" run out on the end of the screw with the screw through the nut in the cross slide shouldn't be a problem. If you made the measurement with the cross slide removed, it is meaningless, as there is clearance between the screw and the bushings in the bearing sufficient to allow that much movement at the rear end of the screw.
