- Mar 27, 2022
- 425
I’m not sure I follow?You can use the existing / remaining teeth of the gear with a round, tapered, stop pin to set in between the gear teeth and enable indexing without a dividing head. Grind a flycutter to the tooth profile to machine the welded up teeth to size. Done this a few times in a pinch . Works.
